iac will not clear baseplate?
Car: 1984 Camaro berlinetta
Engine: LG4 305
Transmission: 700-R4
Axle/Gears: 3.08 open diff
ok back story i have a 96 chevy w/t 1500 i am building a 305 for
engine
305 roller block
350 vortec heads
scoggin dickies vortec base plate
stock runners
stock plenum
bbk/edelbrock throttle body
issue i am havig as i decided to put the intake together as a dry run to make sure it would clear and well the iac housing seems to be hitting the base plate?
any idea why or a way to fix this?
engine
305 roller block
350 vortec heads
stock runners
stock plenum
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: iac will not clear baseplate?
Looks like you need a tpi lower iac housing. Your using a lt1 style iac housing.
Engine: LG4 305
where could i find one with out spending $75 on an aftermarket one?
ebay seems to have nothing
Engine: Lb9
Transmission: M20
Tpis makes one or a used tb in the wtb classified section or eBay.
Engine: Lb9
Transmission: M20
Engine: LG4 305
thanks guys
did not even notice the lt1 ans tpi differences makes sense as this came off of a lt1
Engine: Lb9
Transmission: M20
z28z34man
Jun 16, 2006 12:21 PM
