tpi hard start after warm up and setting
Old Jan 7, 2018 | 10:44 PM
2dordenny's Avatar
Want a title? Post!
My 85 IROC with 305 tpi starts fine when cold but after I drive it then park it for an hour or even 2 hours it starts after long cranking. Could it be the fuel pump regulator?
Old Jan 8, 2018 | 05:37 AM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Re: tpi hard start after warm up and setting
Possibly but I would suspect that the injectors are leaking and flooding the engine when it is warm, the extra fuel helps it start when it us cold. Do not just replace parts trouble shoot the problem. Check the basics first, do you have spark and fuel pressure. If yes proceed to check, for leaking injectors, leaking cold start injector, leaking fuel regulator, and is the temp sensir for the engine reading correctly.
Old Jan 8, 2018 | 10:06 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Check the injector resistance
Then do an injector balance test
Record what you experience on your phone, upload to youtube, which is free and easy.
Also get an ALDU1 cable from moates.net, hook it to a laptop and configure it to run under TunerPro, drive it and log some data to look at fuel trims and sensor info. Or just get a cheap bluetooth scanner from Ebay that will export to a CSV that you can upload to your computer.
Old Jan 10, 2018 | 06:37 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Beyond possibly being fuel related, a bad cap/rotor can cause this issue. Had this issue on a TPI car that had only 49k miles on it but many of the original (and now 30 years old) wear items in place. Like the others have said though, start with the basics.
Old Jan 11, 2018 | 03:53 PM
southbay08's Avatar
stock injectors/multecs are notorious for coil failure, especially when they are warm/hot.
As Pro mentioned check the resistance but do it while they are cold and hot.
Let us know how you make out
Old Jan 19, 2018 | 02:29 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
yes, highly likely leaking fuel injector/s or bad fuel pressure regulator diaphragm leaking fuel into that little vacuum line. Easy to test for that.
Big&BadGTA
Jul 15, 2020 05:11 PM
westsail42
Carburetors
Nov 19, 2017 11:28 AM
bowtie1983ss
Nov 25, 2001 07:03 PM
