Dont Trust That OEM Temp Gauge before you Swap to Lower Temp Thermostat!
Old Dec 22, 2017 | 08:31 PM
westsail42's Avatar
Car: 1983 Berlinetta
Engine: 305 Carbed
I know this is said in lots of places in other threads...
But, do not trust that OEM temperature gauge when considering if your engine is 'running too hot'.
Summary:
I replace bad temp gauge (no reading at all) with another used gauge (worked better, see below).
Replaced gauge sender
Swapped clutch fan for electric fans with a thermo switch set to go on at 185 (the summit racing wiring kit)
Added a 'block temp switch' set to tun on at 200
Had OEM 195 thermostat installed.
The dash gauge consistently read 250-ish when engine is fully warmed.
Fan switch NEVER clicked on.
Block Thermo switch NEVER clicked on.
I read the gauge as the engine was 'running hot', so I replaced the 195 thermostat with a 180.
Dash gauge indeed read about 15 degrees cooler, but...
The ECM started throwing codes complaining about engine running too cool.
I thought maybe it was hotter near the gauge sender (left lower side of engine block), than at the thermostat housing (where fan switch is installed). So I swapped them. Nope, dash gauge still read 250ish with the sender at the thermostat housing.
Finally broke out the infrared temp gun and verified temperature at the side of block is the same at the thermostat housing. Both in the sweet spot of 170-190 degrees).
So, I have three data points saying temperature is < 200 degrees, with a gauge that reads 250 degrees. Which one is most likely WRONG???
The gauge of course...
Moral of the story... double check your temperature readings with something reliable before deciding your engine is 'running hot'.
Old Dec 22, 2017 | 10:59 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Dont Trust That OEM Temp Gauge before you Swap to Lower Temp Thermostat!
A properly working factory temp gauge works fine but I always recommend this to make sure:
https://smile.amazon.com/Mr-Gasket-2...perature+gauge
Old Dec 23, 2017 | 12:00 AM
GeneralDisorder's Avatar
ECM live data. There's really no excuse for not having an ALDL cable and free software to handle this aspect of vehicle maintenance. Manifestly you are doing your own work and you have a computer or some way to post on thirdgen.org so.....
Part of being a mechanic in the age of computers is working WITH the computer. Also infrared temp guns are really cheap, and even thermal imaging cameras have come way down in price. There are soooo many ways to troubleshoot that doing it with Visa by throwing parts at it is completely unforgivable.
Shame.
GD
Old Dec 23, 2017 | 05:48 AM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Since I think your post is a "don't forget the basics" reminder, I'll add to it because way too many people don't understand. It always cracks me up to see someone chase an "overheat" problem with a lower temperature thermostat. A thermostat does not control the max coolant operating temp, it controls the minimum. People need to stop trying to fix overheating with a lower temp thermostat.
Old Dec 23, 2017 | 10:12 AM
westsail42's Avatar
Engine: 305 Carbed
Cool. Never seen those before. Brilliant idea.
Old Dec 23, 2017 | 10:16 AM
westsail42's Avatar
Engine: 305 Carbed
Shame.
GD
Yeah, I was looking at those cables online yesterday. In my case the CCC carb ECM doesn't give out much information. Not much more than could be measured through other means. Maybe one of these days I will shell out $60 for the cable.
Old Dec 23, 2017 | 10:24 AM
westsail42's Avatar
Engine: 305 Carbed
Yes, the thermosat temperature is the 'minimum temperature where coolant will flow' (unless you have drilled holes, which should not be necessary unless you have other problems).
The only time a thermostat replacement might fix an overheating problem, is when it is defective and 'stuck' close. Which is what I originally suspected in my case (it was not).
Old Dec 23, 2017 | 01:15 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I agree with you in terms of min temp. But on the other hand, I've seen some pretty rusty thermostats come out of cars. And who knows if they're opening all the way or just halfway? Stant thermostats are something like $4, $6, or $9 depending on economy/regular/premium choice. For that little amount of money, the best thermostat they offer is worth it to me.
Old Dec 23, 2017 | 04:05 PM
Lurbie's Avatar
Car: 89 Camaro
I see no problem with checking or replacing a thermostat, but too many people want to jump to a lower temp as if that will solve their problem. At best it might mask the real issue.
Old Dec 24, 2017 | 08:20 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Something like this would help aid in determining if a thermostat is opening and closing properly and you can monitor the coolant. I'm thinking of getting one of these:
http://www.jegs.com/i/Cool-View/067/CV0180CH/10002/-1
Old Dec 25, 2017 | 11:35 AM
OrangeBird's Avatar
Car: 1989 Firebird
Looks like a leak in the making to me ....
Old Dec 25, 2017 | 01:06 PM
Wow. Totally getting one of those for my truck. Bling!
GD
Old Jan 5, 2018 | 09:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My factory temp gauge is off, got better after I replaced the sender but is always at least 20F too high. Before I replaced the sender it would redline when my fan came on at 211 and my aftermarket gauge and heat gun read 210.
Old Jan 5, 2018 | 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My 89 has been spot on. One thing to note tho is the half way tick mark is not half way in temp. First mark is 100 then other marked 220. Half way tick usually reads near 190-195 from what i have seen
Old Jan 5, 2018 | 11:59 AM
midias's Avatar
That is a good point, it is not a linear gauge
RCAR7395
Classified Ads Feedback Board
Jun 9, 2008 08:50 AM
PLANT PROTECTION
18
Sep 7, 2002 04:01 PM
