Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
When you can't make the track, what do you trust more?
Old Aug 29, 2002 | 09:59 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
What do you guys think is more accurate, a g-tech or craig moates's "g-tech"? Tomorrow I will make a run with both running to compare but what do you guys think?
Old Aug 29, 2002 | 10:09 PM
Polecat's Avatar
Run both, then go to the track and see which is closer to the 'real' time.. then you can tell us too..................
Old Aug 29, 2002 | 10:36 PM
Hell, I'll have all 3 timers going, but I want to get my CAI put on before I go back to the track, week or so. Anyone have personal experiece?
Old Aug 30, 2002 | 06:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Track time ET should be very close to the same but track MPH will be slower. The MPH on a time slip is a calculated number. The finish line MPH is calculated from the time it takes to go the last 66 feet of the 1/4 mile.
If you take the MPH from the timeslip and multiply that by 1.0072, it should be very close to the g-tech 1/4 mile MPH. That's the factored MPH that the car should be crossing the finish line at since it's still accellerating during that last 66 feet.
Old Aug 31, 2002 | 12:02 AM
I got some numbers. Gtech and moates going at the same time. I let off a bit after the 0-60 test and just held a steady speed until the end, night and many cars around(not too many if I could stop in the middle of the road and launch).
moates
60ft 1.89
0-60 5.75
1/8 9.08
1/8mph 75.17
1/4 14.82
1/4mph 64.22
1/4rpm 1775
gtech
0-60 6.10
1/4 14.82
1/4mph 72.8
Exact same 1/4 time. I was hookin also, my best gtech 0-60 since my flowmast catback w/ cutout closed.
Old Aug 31, 2002 | 08:53 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Steven, is that 1.0072 mult factor correct? I ran 114.2 MPH on a G-Tech but would expect a 109-110 MPH at the track, although I have not made it to the track yet.
Old Aug 31, 2002 | 10:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
It's about as correct as the 1000 foot ET multiplied by 1.19 to calculate a 1/4 mile ET or 1/8 mile ET multiplied by 1.56 to figure out 1/4 mile.
Since there are variables affecting the car no formula is 100% accurate. That number was given to me by hardcore drag racers with sub 9 second vehicles. They say over the years of collecting data from their data recorders, that's the closest number they can come up with.
I have no access to a G-tech to test the theory. The actual speed at the 1/4 mile doesn't affect me anyway. It's only that number on the timeslip that I can use.
Your math is wrong somewhere. If G-tech says you did 114.2 then a timeslip will say around 113.4
Old Sep 1, 2002 | 12:11 AM
BuckeyeROC's Avatar
I wasn't using a formula to estimate my track MPH, just what a friend has told me about his differences between G-Tech and Track MPH, which is around 5 MPH for him, running 13.5's @ 102 at the track and 13.5's @ 106-107 on the G-Tech. That's why I was curious about the 1.0072 factor. I hope to find out for myself next week, I NEED to get to the track.
Old Sep 2, 2002 | 10:45 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
The g-tech accounts for tire spin. The moates does not. I would assume that the faster your car is, the less accurate the moates becomes. And BTW, that 1.0072 factor is crap.
Plant, tell us about your car. Sounds fast to run 14.8 @ 64mph.
Old Sep 2, 2002 | 10:58 AM
I talked with Craig and he also said wheel spin will introduce error. I also tried a run that I blatently(sp?) spun the hell outta my tires and still got a 1.9 60ft so I don't think that reading is accurate at all. I went to the track with a bone stock L98, my 2800stall, and headers with open ypipe and ran a 14.53@96 with a 2.18 60ft time...not taking advantage of the stall. My posted times are with full 3in exhaust and Firestone ss20s which hook decently even on the street. That 14.82 run seemed a bit fast to me also but I went with it because both timers got it. I hope to have a track compare soon.
Old Sep 5, 2002 | 05:51 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The moates software is a good tool to detect tire spin..
Something a 14 second car would notice, but sometimes we don't .. (unless of course it's obviously bad)..
-- Joe
Old Sep 5, 2002 | 05:59 PM
Car: 1991 Firebird
Engine: 427 LSX
no traction in 3 gears? is that neutral, first and reverse?
Old Sep 6, 2002 | 09:06 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
How do these units work? Do you have to install them on the car or does it just detect forward motion or what?
Old Sep 6, 2002 | 09:28 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thats first, second and third, with 26" slicks.. I run a manual tranny.
I'll run 11's if I ever make it up there _BEFORE_ someone drops oil and antifreeze all over the track..
-- Joe
Old Sep 6, 2002 | 12:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I have no clue what the moates is, but the G-Tech plugs into your cig lighter in the car, and you mount it on the windshield like a radar detector. Works off of satelittes I guess.
Old Sep 6, 2002 | 01:08 PM
The moates software is used on a laptop and connects to your car using a aldl cable. It uses speed, time, drag, and weight to calculate all the info. The g-tech is a standalone device needing only power and its calculations are all done using sensed gforces.
Old Sep 7, 2002 | 02:29 PM
BuckeyeROC's Avatar
I have some track times to compare to G-Tech. Since I had to drive to a suitable spot out in the country to G-Tech my car, I will give you my track time when my car was hot, just as it would be by the time I G-Teched it. My best G-Tech time was 12.65 @ 114.2 MPH. At the track with a hot car, I ran 12.656 @ 106.90 MPH. Although I did end up running 12.395 @ 109.53 MPH when the car was cooled off. I would say the G-Tech is pretty accurate ET-wise.
Old Sep 7, 2002 | 02:53 PM
Car: 1991 Firebird
Engine: 427 LSX
First, second and third!!!!! Ha
Old Sep 7, 2002 | 04:01 PM
Car: 99 Formula
Axle/Gears: 342
Yeah, I don't see that combo spinnin slicks thru 3 gears.
AussiePr0nCar
Mar 6, 2020 04:04 PM
xxx3man`
Sep 23, 2015 10:37 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Bryan F
Aug 18, 2015 02:28 PM
86White_T/A305
Aug 17, 2015 12:16 AM
