Hesitation
Old Jan 29, 2018 | 06:35 PM
rotaryracer2002's Avatar
Hesitation
I just installed a new 305tpi stock into my 92 convertible. There is a new fuel pump and filter, new IAC, new distributor, wires, and plugs. I set the timing, IAC, and TPS per instructions. Car idles fine and runs fine except...any time when you initially hit the throttle the rpm falls before it catches. Once it catches it accelerates like it is supposed to. I was told by someone to replace the EPROM but I am tired of throwing parts at it. Has anyone had this same issue?
Old Jan 29, 2018 | 09:43 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Re: Hesitation
Check and make sure there is no vaccum leaks.
Old Jan 30, 2018 | 11:05 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Hesitation
Sounds fuel related since you set the timing. Checking fuel pressure under a load. Might be a fuel pressure regulator or injectors. Sounds like Accel enrichment is lean .
Old Jan 30, 2018 | 05:33 PM
Re: Hesitation
We smoked it before we put the engine in. Noticed the throttle body had a slight leak around the seals. We will smoke it again on friday and I will look at the fuel pressure when the rpm's drop. If it was a lean/rich issue on accel what would be the fix for that?
Old Jan 30, 2018 | 07:58 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Hesitation
I had your symptoms when truck was running rich x 4. Then with some reprogramming, richness went away.
The car on the other hand was rich x 3. A heated O2 (actually just a new one was all it needed) brought it to rich x 2.
If u can get a scanner or some way to see what the ECM is telling you that would be cool
onebad82z
Carburetors
21
Nov 7, 2001 01:50 AM
Tom 400 CFI
Carburetors
Oct 1, 2001 04:10 PM
branz28
Oct 4, 2000 04:50 PM
UVA3rdGen
Sep 29, 2000 11:55 PM
Mike92
Jul 27, 2000 08:26 PM
