LT1 intake question - distributor angle
Old Jan 4, 2002 | 07:04 PM
cfabe's Avatar
Well I milled the 1 3/8 hole for the dist in my manifold today, and milled flat the casting around the hole, took off about .015. When i set the manifolds next to each other I noticed that on the TPI manifold the boss the dist sits on is at an angle to the bottom of the manifold. I machined mine flat. It appears to be about a 15 degree angle. Has anyone else noticed this? Will it be a problem?
Old Jan 4, 2002 | 07:09 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It won't be a problem at all. I don't fully understand why the TPI intake base has a angled distributer hole but compare any other SBC intake including the LG4 are all flat.
I didn't worry about it.
Old Jan 5, 2002 | 01:19 AM
cfabe's Avatar
Thanks for clearing up the confusion.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
