1990 TBI/Auto to TPI/M5 ECM/EPROM question
Old Mar 3, 2018 | 12:05 PM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
I have spent the last three days pouring over the forum and never have read a definitive answer to a question. I'm looking at a very low miles (16K) Formula that is, unfortunately, only a 5.0 TBI/Auto. I would like to know if converting to OEM TPI and T5 would require anything other than equivalent EPROM for a 5.0 TPI/T5 car to work. I know there is a lot of work and parts involved, but I want to maintain a stock appearance while bumping up the power a bit (TPI) and fun to drive factor (T5). Any insight/answers would be appreciated. I have owned four different third-gen cars over the years and now looking to get back into it...
Old Mar 3, 2018 | 12:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1990 TBI/Auto to TPI/M5 ECM/EPROM question
If your going speed density you need a memcal like this.
https://m.ebay.com/itm/90-92-Camaro-...-/162914340207
Old Mar 3, 2018 | 05:05 PM
Drew's Avatar
Unless it's really really really cheap, just buy a TPI car to begin with. The list of what is shared on a TPI and TBI car is much shorter than the list of what's different. You'd need the entire engine harness, ECM, and Memcal. Then after converting to TPI, you've still got a 170hp low output 305. To get TPI performance, you'd have to bump up the compression ratio, change the cam, change the exhaust, change the rear gear ratio.
Really not worth the hassle.
Old Mar 3, 2018 | 05:39 PM
Engine: Lb9
Transmission: M20
If you do go with tpi. You might want to look in the classifieds section for swap parts. Harness & tpi.
https://www.thirdgen.org/forums/engi...pi-intake.html
You can also convert your harness to tpi
https://www.thirdgen.org/forums/tpi/...d-density.html
Old Mar 4, 2018 | 11:09 AM
rt66er's Avatar
Engine: L31 350 TPI
Thanks for the replies. Points well taken. Maybe I'll just be content with a T5 conversion. This is a true survivor car and I really don't want to butcher it up. If I do just have to have better performance, the answer might be to just pull the drive train, mothball it, and drop in something better. This is really just a pre-retirement project; I know it's not a great bang-for-buck situation.
IROCtheThird
17
Nov 4, 2013 04:40 PM
Tuned Performance
Jul 17, 2012 04:01 PM
jshepit
Feb 23, 2009 10:40 PM
90-Vert
Dec 22, 2008 11:03 AM
Sarkee
Aug 4, 2001 09:45 PM
