Passenger valve cover
Old Mar 4, 2018 | 05:30 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Where is the crankcase vent on your passenger side valve cover (front or rear)?
I am replacing tall chrome covers that came with the car, and it's port was on the rear. But nearly all of the pictures I have found show the port to be up front, closer to the TB just like the TBI trucks have.
Old Mar 4, 2018 | 06:12 PM
Drew's Avatar
Re: Passenger valve cover
It really doesn't matter. GM ran em toward the back on carb and early TPI cars, TBI too I'd assume. Later TPI cars they're toward the front.
Old Mar 4, 2018 | 06:17 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Cool, so that little contraption I assume they did, to extend the hose, isnt GM factory.
Old Mar 4, 2018 | 06:50 PM
Drew's Avatar
Right. The molded part is, it's late TPI and not reproduced, so don't throw that away. A stock TPI setup with the rear location has a long steel tube and a short steel tube, with rubber couplers. It runs between the valve cover and injectors.
Old Mar 4, 2018 | 07:06 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
This hose is a good replacement
https://www.ecklerscorvette.com/corv...991-11313.html
MakeitQuick92RS
Mar 8, 2005 11:43 AM
joshwilson3
May 4, 2004 08:09 PM
TraviZ
Feb 28, 2004 11:50 PM
JoshDT91
Jul 15, 2003 01:21 PM
Iroc n roll
Mar 20, 2002 05:41 PM
