Push in filter on passenger side valve cover
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Push in filter on passenger side valve cover
Originally posted by joshwilson3
I have looked and couldn't find any info.
I have done the open element on my 305 TBI. Do any of you guys know of a push in filter that will fit in the passenger side valve cover? Or is there a way to connect the metal tube that sticks out the passenger side valve cover into the bottom of the open element base? Like a size of the hose that would work?
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
you can just put the stock one back in, just make sure that the little piece of wadding is still in it. If you look at the stock air filter assembly the breather is exposed to unfiltered air any way, so i dont see how running it with out it being mounted to the open element would be any different then it was stock. thats how mine is.
-chuck
-chuck
Car: '90 RS
Engine: 377 LSX
-chuck
-chuck
Car: 1991 Chevy Camaro
Engine: 305 TBI
You can put a 3/4" push-in style breather on your car, that is what I have and it is working fine. It looks a whole lot better than the stock one, especially when you have an open element.
Engine: 305 TBI
I am using a K+N breather filter. I got it at Jegs.com. Mine is smaller than the one I found now looking at the catalog but it should definetely still fit. I wish I had gotten the bigger one, though, it only cost $1 more at the time!
The part number is 599-62-1160. It is 3" in diameter and 2.5" tall. It is $19.99
Engine: 305 TBI
The part number for the one I bought according to K+N is 62-1030. It is 2" in diameter and is 1.5" tall.
Yes, you need 3/4" diameter filter. That measurement is for the bottom part that fits in the valve cover. My K+N breather filter looks like these:
I don't know about having high silicon or anything like that. I haven't had any problems with mine, although all I have is a K+N breather, not an engine filter (yet).
Car: 89 RS, 91 GTA
Engine: lo5, lb9
Transmission: t5, a4
I've got the Mr. Gasket one in mine (3/4" one) and it works fine but I had to go the the Help section and buy a grommet that would fit. The one that came with the breather is like 1 1/16" and I couldn't get it to go in. Most all parts stores carry the Help line of products and you'll just have to go in and find the right one (sorry I threw my package away so I don't know the right #).
Engine: 305 TBI
Yeah, I had to find a new grommet too and it took me a while to find the right size. And when I found the right size, it was still hard to get it in the hole!
Car: '90 RS
Engine: 377 LSX
Originally posted by 25THRSS
So 3/4 inch is the correct size for the stock grommet? How snug is it?
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
i'd get a new gromet they arent expensive. I got one from autozone for like $2 and a disposible breather for about $6. when i tryed to remove the gromet in my cover it crumbled.
heres part numbers from autozone the gromet and the breather.
Engine: 305TBI
that one i have has a lip on it, its such a tight fit i used brake fluid to soften the gromet and to make it slick so i could push the silly thing in.
Car: 89 RS
Engine: lo3
Originally posted by ShiftyCapone
No it does breathe filtered air. The stock air cleaner assembly has that square filter built into the side of it where that tube plugs in.
Shifty is right it does breath filtered air. I pulled that little square thing right out of the stock cleaner and put it back on the tube. its only held on by like one or two little clips, no screws or anything fancy. Works fine for me. Its sad, i cant even dig up enough money to buy a $15 pretty one
.-chuck
actually yea...and tehy seal really well with our grommits...takes a little pushing but it will work....Auto Zone has GM Performance and Edelbrock Signature Series Breathers as well...all are abotu the same price...
Car: 2002 Z28
im using the same breather on my car and havent had any problems with it, as long as it filters the incoming air its fine.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
This may sound a little crazy but I cap off the breather hole in one valve cover and just put the pcv valve in the other. This puts a vacume on the crankcase. It helps stop leaks and blow by in my car. It really did cut down on oil consumption. You can actually hear the crankcase "blowdown" if you pull the pcv out of the valve cover with the car running. Unfortunately this setup has been masking the fact that my rings are on their way out. I just noticed the other day that i'm leaving a nice blue trail at upper revs under WOT (no manifold vacume) so It's time for a rebuild. I unhooked the pcv for a quick drive and man does it smoke alot without it. Has anyone else tried this?
the spectre one looks jsut like the edelbrock ones so i should guess their performance will be about the same...im pretty sure the internals are close to the same as well....and hey a few bucks cheeper i would bet!!!
Car: 2002 Formula Firebird
Transmission: 4l60e
I had to run around looking for one for mine. Autozone sells a spectra one that fits perfectly into the stock valve cover with the stock crommet. That is what I use.
Engine: 305TBI
Hmm i got one on my 74 f-body thats been there for 4 years and it still works, its not gummed up or seeping oil yet. just an autozone cheapy
NBrehm
Aug 25, 2015 11:49 PM
