Tube On Passenger Side Valve Cover
Old Mar 8, 2005 | 11:28 AM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
When I recently installed my valve covers (edelbrock), I removed and did not put back a small tube that is running from the air intake tube to the gromet on the valve cover. I just capped it off. The car is not running well exactly. My question is what kind of effect would that little tube have on a stock motor? Is it some kind of vacuum? Is it important on a stock engine?
Old Mar 8, 2005 | 11:31 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I belive its some sort of breather or vapor tube.
I've never plugged mine. But at one time I did have the tube cut short and a mini breather/filter on it.
Old Mar 8, 2005 | 11:43 AM
Engine: 383 Stroker
I think I found my problem.
Thanks dale.
db057
Aug 22, 2015 08:17 PM
Cameeeero
Aug 20, 2015 03:06 AM
1985chevydude
Aug 20, 2015 12:29 AM
Street Lethal
Aug 14, 2015 08:25 PM
Street Lethal
Aug 12, 2015 11:33 AM
