Original injectors ?
Old Mar 10, 2018 | 03:44 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
I have a 85 z28 with a lb9 and i was wondering if these are the original injectors ? Thanks for any help
Old Mar 10, 2018 | 04:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Original injectors ?
Looks like it .
Old Mar 10, 2018 | 05:37 PM
I figured they were. I'm gonna replace them here in a couple months
Old Mar 11, 2018 | 08:41 AM
Vader's Avatar
I'm still running original injectors in my '86. They've been removed and cleaned a few times, but they function properly. Those appear to the same vintage.
Old Mar 11, 2018 | 08:50 AM
I might try and have them cleaned then if I don't just go ahead and buy new ones. I think they might leak a bit because I can smell gas sometimes around the car when I shut it off plus it runs a little rough sometimes
Old Mar 11, 2018 | 10:27 AM
Vader's Avatar
Leaking would more likely be due to 30+ year old O-rings, and not the injectors themselves.
Old Mar 11, 2018 | 10:59 AM
True there's no leaks from outside tho. So must be the lower ones if it is
Old Mar 11, 2018 | 08:57 PM
Vader's Avatar
Fuel aroma and rough running - I the EVAP canister still operating?
Old Mar 11, 2018 | 10:53 PM
Yah I can hear it back firing while idling sometimes. The evap canister is still hooked up. It works to my knowledge, the purge cylinder seems to get a bit hot tho
Old Mar 13, 2018 | 10:48 AM
southbay08's Avatar
Whenever you're ready to clean them...send them on in to us. If you have injectors that do not function properly we will not charge you for them. If you decide to replace the entire set, we will not charge you for the service just the injectors if you decide to purchase from us.
Old Mar 15, 2018 | 02:33 AM
Desertvert87's Avatar
recently purchased an 87 trans am gta 5.0 that has been sitting couple years don't have the cash for new would u be able to service them for me
scottmoyer
Jul 21, 2013 05:06 PM
Foggie Doggie
Northern California
Oct 1, 2012 01:29 PM
j88l98irocz
Apr 6, 2012 07:23 AM
WSU
Sep 17, 2001 11:24 PM
