90-92 MAF
Old Mar 14, 2018 | 07:21 AM
dmm3369's Avatar
Car: 83 Z28 / 89 IROC
Engine: 350's
Transmission: T5 WC / 700R4
Axle/Gears: Posi 3.73
90-92 MAF
I searched around and didn't see anything. I noticed a picture of a 91 TPI engine and didn't see the 89 type MAF like mine. Do the 90-92's have a MAF? I looked on orielly and didn't see any. Reason I ask is I went through 3 aftermarket ones on my 89 to get one that runs good. What can you do to make it like the 90-92's? I will continue to research but thought maybe somebody knew already. I'm sure its talked about in the forums somewhere.
Old Mar 14, 2018 | 07:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 90-92 MAF
No the 90-92 were map sensor not maf
It would require a detailed wiring harness change and new computer to run
Old Mar 14, 2018 | 08:30 AM
dmm3369's Avatar
Engine: 350's
Re: 90-92 MAF
Thanks. I see the map sensor now. Thanks again!
Grumpy
24
Jun 7, 2002 10:15 AM
Jon88GTA
Mar 20, 2002 02:20 PM
Reno
Sep 1, 2001 10:34 AM
