need help on wiring in new model distibuter...
Old Jan 5, 2002 | 09:09 AM
zboss86's Avatar
I hate to post this in an tpi section, but I figured somebody doing the LT1 swap has does this before.
I'm swapping over to an LT1 intake, and it requires the smaller distibuter with external coil from later model thirdgens for clearance.
I thought I had it wired up right but still no crank.
I noticed when I turn the distibuter to alter the timing , the speed it turns over doesn't change. (while I'm trying to start it) So I know that isn't right.
It is firing b/c it shows on the timing light.
I sure it's set in right.
Iginition module is new.
iginition coil is new.
I'm not sure on the first two wires on the ignition module(A,B), and the wires on the iginition coil.
Does any body know a good wiring diagram for this setup? The Haynes manual just puts both distibuters together in one drawing. I'm having a hard time folling it. Please excuse my ignorance.
Old Jan 5, 2002 | 01:57 PM
zboss86's Avatar
alright
I'm pretty sure that I got wired right now. I'm thinking I got a bum distributer.
When I turn the distributer to advance or retard the timing, the timing stays the same.
Would the ditributer cause that or has anybody ever even heard of that happening?
Old Jan 5, 2002 | 06:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You won't see an advance or retard till it's running. It doesn't work that way till over like 200-400rpm. I forget.
You probally have a bad ignition module but you need to check a few things first.
First try some starter fluid in the throttle body, not because we suspect a fuel problem but the ECM won't fire fuel till the ignition module tells it to. If she lights off I'd be buying another module.
If still broke post back with info.
Old Jan 6, 2002 | 01:35 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Here's one of the 89 (for the newer distibuter you put in)
[img]ftp://ftp.diy-efi.org/pub/gmecm/manuals/1227165/89-165v8MAF.jpg[/img]
I think it's draw by Vader, it of a 87
Attached Thumbnails need help on wiring in new model distibuter...-87tpi01.gif
Old Jan 6, 2002 | 08:51 AM
Engine: 4.0L
89IROCZ,
Can you post a picture of a 1990-92 diagram like the large picture above, please?
Edit- nevermind, I found them all.
Old Jan 6, 2002 | 02:55 PM
zboss86's Avatar
true true
"You won't see an advance or retard till it's running. It doesn't work that way till over like 200-400rpm. I forget.
First try some starter fluid in the throttle body, not because we suspect a fuel problem but the ECM won't fire fuel till the ignition module tells it to. If she lights off I'd be buying another module. "
Well I got the distributer used...
I did have to get another ignition module, that was my first problem. Now I'm getting fire through to the plugs.
I'm thinking it's the fuel also, we have the same idea there. Because I sprayed alittle starter fluid into the throttle body. Just kinda funny how we thought alike there. It sounds like it would want to crank with the ether.
I hear the fuel pump priming, but that does mean it's shooting throught the injectors. I'm going to borrow a soleniod light and see if the injectors are shooting any gas.
It'll be Sat. (12th) before I can start back on it. My co-op starts tommorrow. I'll hollar back around then.
appreciate it John and everybody
Old Jan 6, 2002 | 05:35 PM
Engine: 4.0L
Correct, the ignition module fires the infectors below 400rpm, after that the ECM takes over and fires the injectors.
You need to put a test light on those injectors to see if they're getting a pulse. It's only 5 volts so a 12 volt test light will be dim.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Fronzizzle
Aug 9, 2015 01:15 PM
