1989 Firebird 350 no start
Old Mar 31, 2018 | 07:21 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
A friend has been working on my bird since I dont have time. It all started as hard starting and then the FPR needed replacing and that leaked into the brake booster needing it to be replaced. Anyway, he got new gaskets to do the lower and upper intakes. A new oil pressure switch as the old one was shot as well. The car wont start. NOW...I drove it over there and after a few hours I took one of his cars to drive as he pulled mine in the shop. After reassembling the plenum, the throttle cable brushed ever so lightly on the back of the alternator and sparked. Ever since then, it will not start. It will run very briefly for 3 or 4 seconds after starting fluid is sprayed in the throttle body and then shut off.
The injectors ohm at 15.7 or better so they are good. We are thinking the spark knocked out the ECM and its not pulsing the injectors. Ans oddly, the fuel pump will still run for 4 seconds or so AFTER the engine has stopped. It had a reman ECM in it and maybe it went bad. VATS has been disabled so that has been ruled out. Any ideas?
Old Mar 31, 2018 | 07:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1989 Firebird 350 no start
Have you checked the injector fuses ?
The lack of injector pulse could be the ecm or a bad icm.
Old Mar 31, 2018 | 07:42 PM
ken3983's Avatar
All the fuses checked out. Did a continuity test to make sure they were not blown. I was thinking a bad ICM at first, but it does run for a few seconds. I would think it wouldnt fire at all with a bad ICM. Thats why we were leaning to a bad ECM.
Old Mar 31, 2018 | 07:54 PM
Engine: Lb9
Transmission: M20
If your sure it’s the ecm you need a service number 1227165,16198259 or 88999194 & cardone 77-7165 . Any of these ecm will work . The numbers superseded are remanufactured numbers for the 1227165 ecm.
Old Mar 31, 2018 | 07:59 PM
ken3983's Avatar
Thanks for the numbers!!! Keeping fingers crossed its just a bad ECM
KITT KNIGHT
Nov 6, 2014 12:59 PM
bowtietilidie
May 31, 2013 04:29 PM
mr396
Sep 25, 2012 05:00 PM
NoWaySS
Dec 12, 2003 08:21 AM
