88 intermittent starting and idle issue
Old Apr 16, 2018 | 06:34 AM
butchc's Avatar
Car: 1988 IROC
Engine: LB9
My 88 305 tpi has an intermittent issue with starting and idle that both happen at the same time. If the car starts instantly, which is about half the time, it goes to high idle as it should. If it doesn't start instantly you crank on it for like 10 seconds and when it starts you have to keep your foot on the pedal for a few seconds to kept it running and it doesn't idle fast like it should after it will stay running. I have been listening for the fuel pump since all this started and it is running every time. Also the car black smokes a bit and smells rich when it happens. There are no codes and no check engine light. It has happened on a cold start, warm start and hot starts. Either way the car runs fine after you get it going. My guess would be an IAC issue? but not certain how of if that affects starting? Thanks in advance!
Old Apr 16, 2018 | 11:05 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 intermittent starting and idle issue
Have you checked fuel pressure drop after prime ?
I’m thinking leaking injectors or (ninth injector).
Old Apr 16, 2018 | 12:48 PM
butchc's Avatar
Car: 1988 IROC
Engine: LB9
Thank you, will get a gauge hooked up and check that out. WI'll be a few days as the car is out having new AC components installed.
cha_chard
May 18, 2012 12:53 AM
92'STOCKER
Apr 29, 2012 11:11 PM
Wiggles
Apr 17, 2012 01:44 PM
firebird
Nov 25, 2010 11:54 AM
Jeffrey Fontaine
Jun 27, 2010 09:37 PM
