Edelbrock 3860 intake manifold question.
Old May 10, 2018 | 07:45 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm in the midst of swapping out manifolds from the stock one to the 3860 high flow base. There's a provision for something back by the distributor .I have know idea what it's for .It almost looks like the port for an EGR, but obviously it's not. Its kind of on the side just behind the last two ports on the right side of the engine. Is this something I need to make a blanking plate for?
Old May 10, 2018 | 08:14 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Edelbrock 3860 intake manifold question.
It’s a egr feed for corvettes. You can block it and the 1/8 npt coolant hole too.
Old May 10, 2018 | 08:15 PM
Engine: Lb9
Transmission: M20
https://m.ebay.com/itm/87-92-Camaro-...4AAOSwpDdVDCPq
Old May 10, 2018 | 09:27 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Awesome .Thanks for the info and the link .
Old May 15, 2018 | 01:15 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This just gets better as it goes along. The ignition module is hitting the manifold because the top of the rear ports on the left side are to high .How is that possible on what was supposed to be a factory fit manifold from what I gather .Have any of you had this issue?
Old May 15, 2018 | 01:50 PM
Drew's Avatar
Ignition module, ie on the distributor? Or the coil bracket doesn't fit now? Coil bracket is pretty normal. The distributor should clear, the intake casting should be milled away to fit. There is a shorter small cap V8 distributor that was used on some TBI cars. I could see that version potentially not fitting.
Old May 15, 2018 | 01:56 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I ended up grinding a little of the manifold off. Its interfereing with the electrical connection on the black module that's under the cap where the two electrical connectors for the distributor plug into
Old May 15, 2018 | 03:46 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
That part shouldnt be over that part of the manifold. It faces point more towards the drivers seat like the picture. If your over the manifold with it then your distributor is off by 2 teeth or your wires are started on the wrong points on the cap
thtanner
Apr 8, 2018 09:52 PM
Clements408
Jul 17, 2017 02:33 PM
StevenB L98/LS1
Apr 22, 2016 10:44 PM
