ECM not sensing A/C on
Old May 26, 2018 | 10:40 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
Another day. another problem. I'm installing a SD TPI unit, AXXB memcal. I only have a handheld scanner. When I turn the A/C on, the primary fan does not come on and the scanner reads A/C Request:OFF. The idle does not seem to speed up either when the A/C is on. Compressor clutch is engaged.
Did some tests and
-Primary fan will turn on when ALDL A and B are jumped.
-Primary fan will turn on when engine reaches approx 228°F
It seems like the ECM is not sensing that the A/C is on. I measured voltage at C2 connector - C9 green wire at the ECM. Is shows approx 12v when the A/C controls are turned on.
Bad ECM?
12 Sec GTA
Jul 3, 2005 09:34 PM
ZZ28ZZ
Apr 16, 2003 02:50 PM
Grumpy
Feb 2, 2003 04:33 PM
Jim85IROC
Jan 8, 2002 02:24 PM
