fuel pressure regulator trouble
Old May 23, 2018 | 10:14 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
I'm installing a SD TPI unit and installed a new bosch pump at the same time. When the fuel pump runs with key on, the pressure goes to 45 psi. Once the pump shuts off after 2 seconds, the pressure drops to 0 in 5 seconds. I pinched off the rubber return line, and when the pump runs, it goes to 70psi and holds once the pump shuts off. Lost maybe 3 psi over 15 minutes of off time. Seems to be the regulator. I replaced the diaphragm with a delco unit and have the same pressure loss problems. Could the problem be the seat in the regulator? It seems smooth but has a weird coloration in one spot.
Old May 24, 2018 | 08:05 AM
Vader's Avatar
Re: fuel pressure regulator trouble
The hardened disc and seat are lapped to a fine surface finish. I'd suspect the FPR leaking, too.
Old May 24, 2018 | 11:11 AM
wayshegoes's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
hmmmm I did this same test last year, so i replaced FPR with a ac delco, same problem, so I then got a adjustable one, same problem, pressure drops to 0 after key off instantly
Old May 24, 2018 | 02:45 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
https://www.thirdgen.org/forums/tpi/...fuel-pump.html
Old May 25, 2018 | 08:16 AM
wayshegoes's Avatar
so leaky injector, that would be a lot of gas leaking out, im thinking more in the pump
can i install a inline check valve on the return line?
Old May 26, 2018 | 10:22 PM
firestorm's Avatar
Car: Firebird
Engine: LG4
Follow up:
I replaced the whole regulator with another one I got off ebay. No more pressure loss. I even tried with my old diaphragm and it still holds pressure. Must have been that seat that was leaking.
Old May 27, 2018 | 07:41 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Good deai!
tompumped
May 29, 2018 05:18 PM
Jhook
Nov 1, 2012 04:35 PM
SomeGuy25thZ
Jul 11, 2011 09:37 AM
MattODoom
Jan 1, 2006 12:51 AM
