Aeromotive Fuel pressure regulator trouble
Old Jul 11, 2011 | 09:37 AM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone using an Aeromotive A1000 Bypass Regulator?
I have an entire aeromotive fuel system for a 383 LT1 build - A1000 pump and the bypass regulator.
I started the car up for the first time this weekend and get ~26 lbs pressure no matter what i do - at idle with and without vacuum line, with part throttle, again with and without vacuum line. I adjusted the set screw all the way in and basically took it off and still not change in fuel pressure in any of the conditions above. I am trying to get to 46 lbs but dont see any change.
The gauge the the aeromotive gauge supplied with the regulator.
Anyone experience this before? ANy ideas?
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
