Can I get fuel to fuel solenoid from fuel pressure regulator mounted on the return li
Car: Camaro
Transmission: th700r4
Can I get fuel to fuel solenoid from fuel pressure regulator mounted on the return line ??
It is safe ? Should I expect any problems ?
My setup : 305 tbi , Aeromotive Fuel Pressure Regulator #13301 , warlbo 190lb fuel pump .
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Originally posted by TonyC
I was under the impression that you tapped the return line to grab fuel for nitrous, no?
You grab fuel before the regulator.
9192camaro
16
Feb 3, 2019 12:21 AM
