Intake manifold vacuum
Old Jun 22, 2018 | 04:45 PM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
Roughly what kind of intake vacuum are you guys seeing with a decent size cam and heads? I am chasing an issue and wondering on vacuum. I checked my stock L98 and it's about 22in of vacuum and this 87 I'm working on has a 224/230 cam, big heads, about 10.5:1 and a big intake on it and it's around 12-13in of vacuum at idle. Is that about right for the size of cam and intake?
Old Jun 22, 2018 | 08:09 PM
ULTM8Z's Avatar
Re: Intake manifold vacuum
I assume the rpm is the same for both measurements. But yeah 13 is pretty good for that size can IMO.
Old Jun 22, 2018 | 11:10 PM
Car: 1992 Z28 1LE
That was high idle for the stock L98, didn't think about RPM variance, I would assume it drops a little once it's warm. I will warm it up tomorrow and check, but if 13ish doesn't seem alarming then I might be ok on vacuum leaks
CobraEatr
Carburetors
Jan 28, 2010 01:06 AM
zacharyhorn
Aug 9, 2007 09:24 PM
MakeitQuick92RS
Jan 17, 2005 09:52 PM
steve8586iroc
Mar 26, 2004 01:00 AM
smoke the tires
Jun 11, 2002 05:17 PM
