"Code 23"
Old Jul 15, 2008 | 11:52 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
"Code 23"
I just used the paper clip method on my car and it pulled a code 23. It is supposed to be the manifold air temp sensor. Can someone tell me where this sensor is, or show a picture of it? The only symptoms my car has is the torque converter doesn't lock up and it does run a little rich. The "check engine" light comes on and and goes off sporadically. Would that sensor cause these problems?
Old Jul 16, 2008 | 04:35 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: "Code 23"
Well I found the sensor and replaced it. No difference in the way the car runs, but so far no check engine light.
Old Jul 16, 2008 | 09:14 PM
vette gator's Avatar
Car: 85 Z28
Re: "Code 23"
How bad of a job was it to replace your IAT? I've been needing to do mine for a while.
Old Jul 16, 2008 | 09:36 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: "Code 23"
It wasn't too bad, but I do have skinny fingers, LOL. Mine was located under the plenum (i think thats what its called ) towards the back. You just really have to work with it to be able to get your wrench in there. I walked back and forth between the driver and passenger side probably 30 times because I had to work with it from both sides. If you remove the distributor cap it would make alot more room, but I hate to mess with that stuff.
Old Jul 16, 2008 | 09:48 PM
Car: 85 Z28
Re: "Code 23"
So you were able to replace it without removing the plenum? I didn't realize that was possible. I'll look more closely at mine (I have a 5.0 motor), but that would be great if I could do it this way.
Old Jul 16, 2008 | 10:22 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: "Code 23"
Yeah I done it without removing the plenum. I'm not quite skilled enough to remove that yet, LOL.
Old Jul 17, 2008 | 06:40 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: "Code 23"
Well I drove my car today and the code 23 is back. It actually seems to be running worse then before. Now it keeps fluctuating back and forth between 500 and 800 RPM while idling. I guess the TPS is next on the list.
Old Jun 23, 2018 | 10:02 AM
FireChickenwpg's Avatar
Car: 87 GTA ttop
Engine: 5.7 TPI
Re: "Code 23"
I would just like to know if you ever solved this problem. I am having the exact same issue and I cant seem to figure it out. " The only symptoms my car has is the torque converter doesn't lock up and it does run a little rich. The "check engine" light comes on and goes off sporadically. Would that sensor cause these problems? " Is perfectly the same as what is happening to my car, I changed the manifold air temp sensor, coolant temp sensor, throttle position sensor, and MAF sensor within a month of owning the car. Then about a month ago had these symptoms start and its like I cant even rive my car anymore because it is acting really boggy and slow. along with stalling every second time I come to a stop at a light. the last problem I'm having is when I do stop and its running still, I have to tap the gas to kick it down like a carbureted engine, it sits at 800-1000 rpm before I tap the gas and it goes down to 500 (or stalls out instantly.) any help would be sweet if anybody sees this of course I know this post is 10 years old.
Old Jun 23, 2018 | 05:56 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: "Code 23"
Have you replaced your mat/iat sensor ?
The tcc lockup doesn’t have anything to do with the code 23.
Old Jun 23, 2018 | 06:36 PM
Car: 87 GTA ttop
Engine: 5.7 TPI
Re: "Code 23"
Yes I've replaced the mat sensor, that's right after the code came up the first time, as for the TCC I was just hoping the original poster but that happens too. I guess unrelated problem...
Old Jun 23, 2018 | 06:42 PM
Engine: Lb9
Transmission: M20
Re: "Code 23"
Look at Post 4 in the link for the tcc schematic. You can use a test light on pin f on the aldl to see if it’s getting power during tcc lockup command.
If it is sounds like it’s the tcc solenoid.
https://www.thirdgen.org/forums/tran...51750-tcc.html
If you have a code 24 I could see tcc not locking up with the loss of Vss signal.
It’s hard to get a response from a ten year old thread. And would you trust max hheadroom .
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
