89 firebird 350 tpi running rich
Old Jun 23, 2018 | 02:12 AM
Jpeterjr's Avatar
Ive replaced fuel filter egr valve plugs wires rotor dist cap thermostat, o2 sensor , injectors, engine coolant sensor . Inlet air temp sensor, cut out catalytic converter.stalls out barely idles timing set to soecs tos sensor set to specs still runs barely any suggestions ????only thing i havent replaced is ecu thats next907-347-2528 any suggestions are appreciated thank you
Old Jun 23, 2018 | 07:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 firebird 350 tpi running rich
Any fuel coming out of the fpr vacuum line.
Any error codes ?
Maf error codes ?
Old Jun 23, 2018 | 07:10 PM
Jpeterjr's Avatar
Its empty and disconnected
Old Jun 23, 2018 | 07:29 PM
Engine: Lb9
Transmission: M20
terrorsquad77
Aug 10, 2010 11:34 AM
tchernobog
Sep 11, 2009 10:51 AM
RlphKnndy496
Apr 16, 2008 08:34 PM
thegeezer
Carburetors
Sep 8, 2004 04:03 PM
