long tube headers
Old Jan 6, 2002 | 04:54 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
long tube headers
I know this probably belongs in the exaust section but I wanted to ask my fellow TPI owners what there favorite headers are. I am running a 350 tpi soon to be 383 or 406 built for torque not horsepower. I want a good set of headers such as the slp's but would prefer a long tube or tri-y if there are some good ones out there. I don't want to give up ground clearance because I am lowered but I don't mind ditching the air tubes or moving the cat if it matters. Thanks for your help and oppinion.
Tyler
Old Jan 7, 2002 | 12:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If you dont want to give up some ground clearance go for SLP....
Old Jan 8, 2002 | 12:37 AM
Eighty5TransAm's Avatar
you wont give up much clearance on the headers but the y pipes gonna scrape. If your building it for torque then go with the LT's
Old Jan 10, 2002 | 05:01 PM
HotRod's Avatar
Car: 87 GTA
Yes I am building the engine for torque so I was interested in long tubes. Why would the longtube headers y-pipe scrape more than a short tubes assuming it was the same O.D.? Does anyone have experance with a brand or LTs?
Thanks for the help.
Old Jan 10, 2002 | 05:21 PM
the long tubes collector goes past where the stock location of the y pipe would be. So you have to run a y pipe under your tranny mount
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
