Where is the MAF Sensor Located on the V8 305 TPI
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where is the MAP Sensor Located on the V8 305 TPI
If you have a 90-92 tpi it’s on the plenum rear on the passengers side.
Engine: Lb9
Transmission: M20
Re: Where is the MAF Sensor Located on the V8 305 TPI
Sorry I misread I thought you said map. The maf is on the intake bellows in front of the Throttlebody 85-89 tpi.
