Fuel pump problems?
Car: 88 Pontiac firebird
Transmission: 5 speed
Fuel pump problems?
My vehicle keeps randomly dying and has troubles turning on. I automatically thought fuel pump. So I replaced fuel pump and filter along with the sending unit. It still had the same problem so I replaced the fuel pressure regulator and still the same thing. I figured maybe the fuel pump was a faulty one so I replaced it again and still same problem.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel pump problems?
First thoughts would be icm or injectors. You might want to ohm the injectors. Does it fire right back up a intermittent issue or does it struggle to fire back up ?
Engine: Lb9
Transmission: M20
Not sure if you have tpi or tbi, but you should check for spark and injector pulse or spray if it’s tbi when it occurs. A intermittent issue can be a bear to find.
I replaced the Icm so far it's doing good still lack of power but I'm facing the hard truth that the engine is getting a little blow by action. I'm probably just going to run thick oil Haha. But thanks, I didnt of ignition because it didnt feel like it but I guess it was.
kowboy59
Nov 7, 2011 09:36 PM
rsrsrs
Dec 13, 2006 01:46 PM
Mr_Metal
Aug 23, 2006 12:42 AM
Mr_Metal
Aug 22, 2006 11:23 PM
Mr_Metal
Aug 22, 2006 02:18 AM
