smokey on startup all of a sudden
Old Jul 17, 2018 | 04:23 AM
Dazza Wilton's Avatar
350 TPI speed density setup.
All of a sudden my engine is very smokley on startup and seems to have oil coming out of tail pipe when i rev it cold
engine oil on air filter side of throttle body
pcv valve working correctly
once warm no smoke
I reecntly had a sticking ICV but now doesn't seem to be working at all (no idle up when cold anymore)
ANY thoughts would be great
Old Jul 17, 2018 | 07:25 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: smokey on startup all of a sudden
Pull the valve covers.
Inspect oil seals on valves.
Now, it COULD be a failed piston ring letting combustion gas past the piston, and over-pressurizing the crankcase, and blowing oil into the intake.
But, Occam’s Razor and all,... I’d inspect the valve seals as a first suspect.
327_TPI_77_Maro
Oct 2, 2006 12:03 PM
92GTA
Oct 28, 2004 01:36 PM
jimbo
Oct 25, 2000 09:43 AM
GTA88
Oct 6, 2000 10:45 AM
