1991 Pontiac Trans Am - horrible acceleration
Old Jul 19, 2018 | 09:21 PM
whostorm05's Avatar
Car: 1991 Trans Am
Hi Everyone,
I purchased an Actron 9690 scanner to try and help determine why the more throttle I give the car the less it seems to want to respond. Checked and dialed back timing a bit, replaced plugs and plug wires and the throttle position sensor. Hooked a fuel pressure gauge up and it didn't seem to jump around much when at WOT, but I had it taped too low on the windshield to see the actual #'s - I think it was somewhere north of 30 though. I need to try it again but have someone with me to watch the gauge.
I noticed when the car was at idle the "Knock Sensor" value was all over the place when watching live data on the 9690. I'm having trouble determining if that's normal or not? I forget the average number but it would jump all over the place from around 50 to several hundred. Does anyone know what I should be looking for in regards to a "normal" number for "Knock Sensor" when at idle?
1991 Pontiac Trans Am, 5.0 TPI
Old Jul 19, 2018 | 10:36 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 1991 Pontiac Trans Am - horrible acceleration
Check your fuel pressure at idle and then stab the throttle in park and see what they read. Should be 41.5
Old Jul 19, 2018 | 10:57 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
You seem to think the problem with your acceleration has something to do with the information the knock sensor is providing to the ECM.
Have you tried disconnecting the knock sensor, and testing to to see if the absence of knock-sensor data to the ECM produces any change in the symptom?
Old Jul 20, 2018 | 11:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by whostorm05
Hi Everyone,
If that is the knock counts it should be zero. The ECM won't retard the spark timing at idle, but if there are counts while moving that will absolutely kill power.
Also, if the injectors haven't ever been replaced they are likely bad. The coils short out preventing the ECM from firing them. But this usually manifests as an engine that is cutting out (on/off/on).
RBob.
Old Jul 20, 2018 | 11:43 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you get a new knock sensor ohm it before you install it. RockAuto and other parts stores have sold a member I was helping the wrong sensor. I don’t know the correct part number. From the center pin to the housing it should be 3.9k ohms.
Old Jul 23, 2018 | 08:57 AM
Midlife Cruiser's Avatar
Car: 69 Camaro and 69 Chevelle SS
Engine: Camaro is FB385, Chevelle is 396
Transmission: Camaro is 200-4R, Chevelle is 4 spd
Axle/Gears: Cam 9 inch 3.70, Chev 12 bolt 3:23
I used a Standard KS3T knock sensor. I used it for a 91 TPI setup on a 5.0 Liter. Be sure to measure it at the store, sometimes you get the wrong one in the box. It should read 3.9 Ohms. The TBI uses the KS2T and that will read 100 Ohms but the TPI needs the KS3T. "Tuned Performance" helped with my project. It was a local parts store that sold me the wrong sensor, not Rock Auto.
OmgItzCheerilee
Oct 14, 2014 09:40 AM
SassyCamaro
Oct 23, 2008 01:08 AM
cas0484
May 6, 2004 02:46 PM
aaron7
Oct 31, 2003 08:35 AM
quicklil87lt
Carburetors
Mar 4, 2003 07:14 PM
