Horrible idle, stalls after acceleration... help!
Old Oct 30, 2003 | 11:20 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
My car will not idle. It will start up and go from 1200rpm to 200, back and forth, till it dies. If I'm cruising along I notice nothing, no misses, no problems. But then if I put it in neutral (T5) it stalls right out, doesn't even try to idle.
Chiltons ( ) says that it is a problem with the EGR system, or the ECM. Maybe cracked vacuum lines? I just don't know where to start.
I figured that maybe one of you have had this problem and know what to do!!!
Old Oct 30, 2003 | 12:31 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Sounds like the IAC valve is bad. It controls the idle. Try cleaning it. I think if you had a vacuum problem you would have stuttering more often.
Old Oct 30, 2003 | 01:25 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I've heard that before... but where is it? And, how do I go about cleaning/replacing it?
Thanks!
Old Oct 30, 2003 | 02:16 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Located under the throttle body (a 4 prong electical connector from the harness plugs into it).
There are a few good posts on the boards about cleaning it and resetting it.
Search for IAC reset and it will bring you to the info you need.
Old Oct 30, 2003 | 03:16 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
if this just happened suddenly, its also possible that the pickup coil in the distributor is crapping out on you...had the same sort of problem with a bad idle, but would drive OK above like 700RPM. as a last resort, I swapped distributors(used same cap/rotor though), and that fixed the bad idle surge/stalling. Apparently in 1987(my car) it is a common problem, 88 is probably similar. Hope that helps.
Old Oct 31, 2003 | 08:35 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I don't know if it happened suddenly to the guy who owned it before me, but I bought it last October, and it was doing it then lol
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
rjcme
Sep 5, 2015 01:23 PM
