Help with fuel lines from sending unit
Old Aug 6, 2018 | 02:44 PM
MiROC_89's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Transmission: 700R4 auto
Axle/Gears: unsure
I'm pretty sure this has been but I haven't been able to find it in the Forum.
89 iroc, 5.7 tpi. I had to change the fuel pump so I went ahead and went the route of lifting up the back and taking the tank out, with a helper. Before I could get to the garage he had unhooked the lines and removed straps. Break for vacation travel occurred, and I for the life of me I cannot remember which line hooked where to the lines running up to the motor.
sending unit has 4 lines an only the 3 going to the motor. I know which one the supply is but what is the deal with the extra one? I've tried and tried to remember what it looked like sitting in there before it was unhooked if anybody could help me label these I would greatly appreciate it.
Old Aug 6, 2018 | 03:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Help with fuel lines from sending unit
One is to the tank vent (UFO looking thing)
Old Aug 6, 2018 | 04:03 PM
MiROC_89's Avatar
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: unsure
Thanks man. I was wondering what that was for
Appreciate the help
Old Aug 6, 2018 | 05:36 PM
Drew's Avatar
You should have 4 lines. The feed is the one that has threaded fittings. Then you have the return line, a vent line to the charcoal can, and then the relief valve.
NoEmissions84TA
Apr 30, 2017 10:41 AM
Donald Croes
Jul 3, 2016 12:19 PM
phasevariance
Carburetors
Jun 25, 2012 06:49 PM
DFIance
Aug 16, 2002 04:32 PM
