Ram Air Duct kit
Old Aug 28, 2018 | 08:42 AM
IROC406's Avatar
Car: 1989 Chevy Camaro IROCZ
Engine: 355 TPI w/ EBL Flash
Axle/Gears: 2.77
Ram Air Duct kit
Hello everyone.
I have checked this site for kits and came across Hawk's RAM AIR DUCT kit which looks nice but how well does it fit? Anyone have any experience with the installation as far as the sealing quality? I am looking to make sure the ducts fit nice enough to reduce any leaks. I understand sheet-metal perfection doesn't exist but overall how is the kit?
Old Aug 29, 2018 | 11:47 AM
IROC406's Avatar
Axle/Gears: 2.77
Re: Ram Air Duct kit
Does anyone know if doing this mod causes overheating issues at least?
Old Aug 29, 2018 | 11:50 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Works good does not cause overheating.
Old Aug 29, 2018 | 11:55 AM
IROC406's Avatar
Axle/Gears: 2.77
SWEET. THANK YOU
Old Aug 29, 2018 | 11:57 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
No problem
Old Aug 29, 2018 | 08:41 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Originally Posted by mmadden55
No problem
No overheating for me, in the south Florida heat. I did remove the lights also.
Old Aug 30, 2018 | 12:08 PM
IROC406's Avatar
Axle/Gears: 2.77
Thanks everyone. I am going to be doing this. Someone relayed a message to me that Dyno Don has a set for sale so I am hoping to get them. New they're $99 now, not sure about shipping.
Any input on this subject? Difference in throttle response around 50 mph? Fitment issues? How much material should I leave after cutting the baffles?
Old Aug 31, 2018 | 07:15 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
You will have to remove the plastic duct work that funnels air to the radiator. The scoops attach to the bottom on the factory airbox. The way the filters seal is not changed. It does block some air from the front to the radiator so you will lose some cooling. If you fan/fans are working you should be fine. If you already have cooling issues these will exaggerate them. You can hear the engine sucking air in from the front and I want to say it pulls harder in the higher RPMs but, I don't have any times or dyno runs to back it up.
Edit found some pics from when I did my install.
ted gerlach
Exterior Parts for Sale
19
Sep 13, 2008 03:45 AM
bdiroc
Mar 21, 2004 06:22 PM
hndsm17
Aftermarket Product Review
Sep 22, 2002 11:37 PM
stuart69427
Jan 26, 2002 09:09 PM
