TPI No Spark
Old Sep 26, 2018 | 06:05 PM
David W's Avatar
TPI No Spark
Hello everyone,
I am having an issue with my 86 z28 TPI system. I was able to start and get it running before. Now it will not. I am not getting any spark to the plugs. I have looked for spark by removing a plug and grounding and while cranking, no spark. I have hooked the multi-meter up to the battery 'in" wire on the distributor and it has 12v and while cranking it does drop to around 10- 9.5 volts. The distributor is brand new, the cap, coil, etc. All new distributor system. I never had a problem getting it to fire, worked perfect before, then I changed the alternator with a new one and now it won't start. Any ideas?
Old Sep 26, 2018 | 08:48 PM
Abubaca's Avatar
Re: TPI No Spark
Ignition module? They're known to go bad. ...are the injectors firing? If the module isn't sending the ECM a signal, you wouldn't see fuel either.
Old Sep 27, 2018 | 06:28 AM
David W's Avatar
Re: TPI No Spark
I put the noid light on and it does pulse. I am getting fuel, I put a new fuel pump in and I can hear it and the lines defiantly have pressure. Just no spark. I will take the distributor out tonight and check it. Its brand new, so we will see.
Old Sep 27, 2018 | 12:24 PM
Abubaca's Avatar
Re: TPI No Spark
well I guess ya trace it back from the plugs. Is the coil firing? ....I've also seen the black and grey coil connectors go bad. Not sure how yours is wired on an 86...might be different.
Old Sep 27, 2018 | 12:38 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI No Spark
86 is coil in cap hei, if you have injector pulse and no spark sounds like you have a bad icm, or coil.
Old Sep 27, 2018 | 10:27 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: TPI No Spark
Agreed, icm or coil.
breathment
Jan 23, 2020 03:43 PM
9014josh
Mar 31, 2009 09:10 PM
ptc92rs
Oct 24, 2001 01:14 AM
zedder 1 9 9 0
Jul 9, 2001 11:28 PM
ChevypickupTPI
Oct 26, 2000 10:42 AM
