BackPressure
Old Jan 8, 2002 | 12:19 PM
Drekken's Avatar
BackPressure
I know that by getting a bigger exhaust you are decreasing back pressure and I heard you could have too much backpressure? Could someone explain what backpressure is and how it is important? ;-) Thanks!
-Tom
Old Jan 8, 2002 | 01:26 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Back pressure is essentially the pressure level in your exhaust system. You can test it by screwing a pressure gauge into the fitting your O2 sensor is in. Anything over about 2.5 lbs is excessive.
Consider, your engine is a pump. If it has to work to get rid of the exhaust gases (high backpressure), it will not operate as efficiently as it could. With low backpressure, the exhaust gases flow nicely out the end of the pipe, and the system works fairly well.
Causes of high backpressure are generally a clogged cat convertor, or simply pipes that are too small for the application. (A one inch exhaust on a V-8 would be woefully inadequate....)
Hope this helps.
Old Jan 9, 2002 | 09:01 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
https://www.thirdgen.org/messgboard/...ML/005393.html
an earlier post of mine that addresses the relevant concepts...
formula_novice
Sep 5, 2015 03:58 AM
86White_T/A305
Aug 17, 2015 12:16 AM
SomeDodgeGuy
Dec 21, 2002 01:40 PM
ORAY777
Apr 8, 2002 10:13 PM
Joel Geerling
Dec 5, 2001 01:04 AM
