TPI throttle body cover function
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
I know it wouldn't be designed and on there, but I've scoured the internet as well as the forums here and all I find is cool pretty replacements, but nothing in depth about the function of the chamber beneath the cover. I'm also wondering if a bad gasket/leak would affect idle or performance in any way.
Any gurus out there that has this information that could share? Many thanks in advance, any input is appreciated!
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: TPI throttle body cover function
Part of airflow for idle circuit w throttle blades closed?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can see how the large vent line for the pcv connects to the air inlet on the upper side of the front of the throttle body.
truckguy
Oct 24, 2016 02:23 PM
89fbirdformula
Aug 16, 2010 08:30 PM
Wayquick4u
Feb 6, 2001 09:42 PM
