Where do you get a throttle body gasket for a 58mm throttle body?
Old Feb 6, 2001 | 02:29 PM
Wayquick4u's Avatar
I need to change the gasket because of a vacuum leak. The old gasket i made myself and it apparently didnt work to well. Any where i can pick up one that will work?
Old Feb 6, 2001 | 02:55 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
The GM dealer still has them, I think I paid $9 for mine.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Feb 6, 2001 | 09:42 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I got mine from Lingenfelter.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Sep 4, 2015 07:57 AM
neekolzun
Aug 24, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
