LT1 throttle body IAC housing, on TPI based throttle body, i HAVE to for clearance!
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
heres some pics to show what my issue is...
before ya'll say flip the rails around and run them like holley suggest's..it aint gonna happen..i like how i have them routed, and fuel lines are already made and routed!
having looked at the IAC housing on the LT1 throttle bodys, it looks like the IAC motor is much shorter, and the connector faces FORWARD instead of pointing to the pass side.. looking at pictures, it looks like the LT1 iac, will bolt directly to a TPI tb..anybody tried this?
heres the issue im running into.
and an overall shot cuz its SEXY! haha
Re: LT1 throttle body IAC housing, on TPI based throttle body, i HAVE to for clearanc
This is an interesting question. If we could prove this works that will give us an option to make working on the TPI even easier.
On Probation
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
just in case you dont find one, i found a few decent priced units..
http://cgi.ebay.com/ebaymotors/LT1-t...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Chevr...Q5fAccessories
On Probation
looking them over, my 89 formula seems to have the 85-88 style cable..but, i HIGHLY doubt its ever been changed...
i had planned to swap to the "89-97" style late model tpi/lt1 cable setup, and just use the LT1 throttle body, but the lt1's style TPS puts the sensor right on top of the fuel rail haha...i cant win for anything here!
but luckily, it looks like the LT1 iac will bolt to the tpi TB..with any luck! for the better anyways, the LT1/LS1 style IAC motor is far superior!
Plug the end of the rail to run the injectors in series. It will clear
The LTx IAC housing swaps over just fine, but be aware the newer unit requires a new plug and has a different operating range than the stocker. Read about it in the OBDII TPI sticky. It will work, but operation will never be perfect
On Probation
i cant plug the rail, that -6 fitting is for the nitrous kit fuel feed
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I don't know if you solved this yet but I figured something like this would be your easiest and cheapest solution...http://www.casperselectronics.com/st...oducts_id=1009. It's for the IAC valve on the Grand National 3.8, but the same square 4 prong connector was used in many GM vehicles including the TPI F-bods.
Or if you've figured out a way to use an LT1 IAC housing, they make a plug and play harness for that...http://www.casperselectronics.com/st...oducts_id=1073
Hope that helps.
On Probation
Hope that helps.
Hope that helps.
since i havent found an lt1 tb local, i might go with that extension harness, thanks man!
1992 Trans Am
May 10, 2023 07:19 PM
Sanjay
Aug 12, 2015 03:41 PM
