Missing Maf connection
Hello all,
Just picked up an 88 gta firebird. While doing the once over I noticed the check engine light. Did the jumper on the ecu trick. And it was throwing a 33 and a 36. So I went to look at the maf and noticed that there was no wire running to it. How is this normally routed? I am trying to trace it down so I can plug it back in but I put goes in to a huge bundle right out of the relay. Any help is greatly appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Missing Maf connection
It comes from the loom next the the tps/iac and tps.
https://www.ebay.com/itm/85-89-Camar...-/121002704081
