missing connection need help dont know what they are
Old May 21, 2011 | 11:38 AM
4g63's Avatar
so i picked up a 3.1 v6 1990 camaro and i have some loose conections one i know is a vacuum line but dont know to what and the others look like a sensor here are some pictures
<a href="http://www.flickr.com/photos/50529416@N08/5743521820/" title="IMG00300-20110521-1229.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5061/5743521820_4214f83236.jpg" width="500" height="375" alt="IMG00300-20110521-1229.jpg"></a>
<a href="http://www.flickr.com/photos/50529416@N08/5742967869/" title="IMG00301-20110521-1229.jpg by letsgetwasted, on Flickr"><img src="http://farm3.static.flickr.com/2532/5742967869_05112aebae.jpg" width="500" height="375" alt="IMG00301-20110521-1229.jpg"></a>
Old May 21, 2011 | 11:54 AM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
Re: missing connection need help dont know what they are
Does your wiper fluid spray?
Is this a red wire? I have the same thing unplugged and I don't know what it is. And I had a crappy alarm system with the speaker in the same spot.
Old May 21, 2011 | 12:04 PM
4g63's Avatar
the first thing is a vacuum line i just dont know to what it runs along the fender and i found the spot where it got cut and it kinda goes down to some where
Old May 21, 2011 | 12:14 PM
4g63's Avatar
and yea the small one to the right is red the big one is like a blueish color
Old May 21, 2011 | 12:51 PM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
Vacuum tubing and washer fluid tubing look the same and I asked if your wiper fluid sprays because of it's location.
I just went out there and looked. The vacuum line goes to a T in front of the washer fluid reservoir, it continues on to the cruise control servo on one side of the T and the other line goes down below the battery to a plastic ball that you can see if you poke your head under the bumper. What it is, I have no clue but that's where it goes. Vacuum reservoir maybe?
I have no clue on the wires, just that I have the red one disconnected too.
Old May 21, 2011 | 12:54 PM
4g63's Avatar
i know they look the same but i heard hissing thats how i knew it was a vacuum, what T by the tank? i dont have a T please show picture?
Old May 21, 2011 | 01:03 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
the hose is either the wiper fluid bottle(check that dont assume) or it goes down to the vacuum ball inside the fender. you can see that from the underside of the car. it holds vacuum for your heater controls and such. its not really needed you can just plut it if you want. i dont have one anymore on my car.
Old May 21, 2011 | 02:54 PM
4g63's Avatar
so would that explain why when i turn the air on nothing happens?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
devilschariot
Feb 25, 2016 03:08 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
