Oil pressure switch
Old Apr 21, 2019 | 02:05 AM
Gizmoz28's Avatar
Transmission: 5 sp
Oil pressure switch
I have an 88 iroc 305 are the oil pressure sender and the oil pressure switch connected I'm asking cause I dont have a oil pressure sender on the car rite now would this cause the oil pressure switch not to work rite and make the engine shut off or is the sender just for the gauges thanks
Old Apr 21, 2019 | 10:54 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Oil pressure switch
How many wires on the oil pressure sensor?
Oil pressure switch will NOT cause the car to stall. It is a backup power source for the pump in case the relay fails. That's it. Otherwise, your car would NEVER start until you cranked it long enough for oil pressure to come up.
Old Apr 23, 2019 | 07:41 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Sender is for the gages
Switch is a backup for the relay as stated above.
Neither will prevent your engine from running.
Abubaca
Jul 18, 2010 06:22 PM
Matthew91-Z28
Oct 15, 2006 03:40 PM
gta88 flamered
Jul 16, 2005 12:08 PM
soulbounder
May 4, 2002 12:58 PM
soulbounder
May 4, 2002 11:44 AM
