Missfire after distributor removal
Old Jun 8, 2019 | 04:15 AM
kt350's Avatar
Car: 88 iroc-z
Engine: 5.7tpi
Transmission: auto
Can't figure this one out, I removed the distributor in my 88 iroc 350 so I could replace the oilpressure gauge sender.
When i put it back together I've got a miss. Yes i've set the timing correctly and the plug leads are all connected to the correct plugs. This is where it gets strange I pulled the plug wires from the left bank one at a time and they are all firing correctly. For the right hand side I had to pull the plug wires from the distributor cap (car has been converted to right hand drive) when I remove any plug wire from the right bank there is less impact than the left bank its as though they are all half working. I replaced the distributor cap but it made no difference. Anyone got any ideas?
Old Jun 14, 2019 | 02:14 PM
chrias's Avatar
Re: Missfire after distributor removal
Remove distributor cap, set the motor to top dead center on number 1 cylinder (0 degrees on the timing mark) and see where your rotor is pointing. It should be pointed towards number 1 cylinder (between 5-6 o'clock). If it isn't then your distributor is off by a tooth. If it's pointed around 11-12 o'clock then your distributor is out 180 degrees. Also make sure your wires are in the right order. 1-8-4-3-6-5-7-2
-- 6 -- 5
3 -------- 7
4 -------- 2
-- 8 --- 1
todd200
Nov 6, 2002 07:13 AM
breathment
Oct 11, 2002 06:35 PM
breathment
Oct 28, 2001 12:20 AM
lodavis
Apr 5, 2001 01:22 AM
