I think my tps is bad ?
Old Jun 8, 2019 | 07:27 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Can anyone gimme a symptom feeling of a bad or starting to fail tps
My car is just the last few days no engine light
It just feels like when I'm stopped ideling when I just crack the gas as little as I can it doesn't go it hesitates falls on it's *** and then as soon as I crack the gas more it drives fine
May be my tps or bad wiring tps clip
I tested it .54volts just now to make sure
Let me know
Ty
Old Jun 8, 2019 | 08:57 PM
ULTM8Z's Avatar
Re: I think my tps is bad ?
With the volt meter hooked up, sweep it from 0 to WOT slowly and watch the voltmeter. It should be a smooth linear transition to 4.5 to 5V.
Old Jun 8, 2019 | 09:28 PM
bensbaby's Avatar
Engine: 383 built
I already did that and it looked normal
Are the pigtails bad ?
Old Jun 9, 2019 | 04:46 PM
bensbaby's Avatar
Engine: 383 built
I just fixed it
I did a 5 psi boost leak test and it had I big leak at the intake tube to tb I just adjusted that and fixed it
And when I had the intake tube off the new aftermarket rebuilt mass I bought locally a year ago the front screen came off and was crooked in front of the sensor and the rear screen was intact and the rear screen trim was loose also dangling in the pipe
So I just took both screens out
And the tb 230 k has a major leak in the o ring seal on the driver side and a minor leak on the passenger side
So I need to get a bbk 58mm tb anyways
But for now the throttle tipping in was fixed
Darkshot
May 4, 2006 05:40 AM
Slow89Iroc-Z
Jul 5, 2002 01:40 AM
MikeT 88IROC350
Mar 16, 2002 04:08 PM
