90 camaro only moves in drive , it has no reverse or neutral, it starts in park but
Old Jun 23, 2019 | 04:00 PM
carstamper's Avatar
My 1990 Camaro IROC Z drives, It will not go into reverse,or neutral. I shut the engine off & put it in park,it seems to mold. I start the car it lunges forward as it is in drive. the shift lever moves up & Down but is is still in drive, I took the council cover off it looks ok. what is wrong. Mu\t car has 50,000 miles on it. is there a solenoid somewhere?
Old Jun 23, 2019 | 04:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 90 camaro only moves in drive , it has no reverse or neutral, it starts in park b
No shift solenoids. Have you checked the fluid leaves and to see if it’s burnt.
You should probably do a Post in the transmission section not Tpi.
Tootie Pang
Sep 16, 2017 05:12 PM
maroe624
Mar 11, 2016 09:08 PM
RAV3N
Jul 21, 2005 04:05 PM
Z28cross-fire
Sep 1, 2004 08:48 PM
