question about replacing the fuel pressure regulator
Car: 1987 Formula
Engine: 5.0
Transmission: 5-speed
87 Formula; 5.0 L; 5-speed; low fuel pressure. Idles okay - stumbles bad as soon as step on gas to pull out. Fuel pressure at idle is around 18 psi (should be around 40). I picked up a new pressure regulator. The new regulator looks exactly like the old regulator. The new regulator included a baggie with 8 O-rings of various sizes. Why? What are these for? The original regulator didn't have any O-rings anywhere. There was no mention of the O-rings in the minimalist instructions that came with the regulator. Unfortunately, one of the tamper-proof T10 torx bolts broke off and now I have to deal with fixing it.
Any guidance would be greatly appreciated!
- Jimmy
- Jimmy
Car: 1987 Formula
Engine: 5.0
Re: question about replacing the fuel pressure regulator
Update. In the process of putting the new pressure regulator on, one of the six tamper-resistant T10 screws broke off. I attempted to drill out the broken screw and put in a self taping screw - but it leaks. Does anybody know the part number for the pressure regulator base assembly? Is there any chance I can find a replacement base assembly or will I need to replace the entire fuel rail assembly? Any ideas or suggestions?
Thanks. Jimmy
Thanks. Jimmy
Car: 1987 Formula
Engine: 5.0
The saga continues. As mentioned above, one of the TT10 screws broke off when putting the new regulator on. I ordered six new screws from Fastenal. All they had that were close were slotted screws #6 x 40. I just tried the new screws and they start but only go in about 2 turns before stopping. I got out a powerful magnifying glass and it looks like these screws have 42 threads/inch. Does anybody have any idea where I can order screws these oddball screws? I haven't visited the junkyards yet, but I suspect that is my next step.
Does anybody know the exact size of these six screws?
thanks.
- Jimmy
p.s. In the above diagram added by badSS; these are the six screws that attach the regulator to base (#240).
thanks.
- Jimmy
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
A lot for screws but they have them on eBay.
if you need a fpr body let me know I have one I’d sell.
https://www.ebay.com/itm/TPI-Fuel-Pr...oAAOSwzd9cLOmJ
Car: 1987 Formula
Engine: 5.0
Thanks! I don't see the size listed on the ebay link... I'll post a question to the seller.
Car: 89 IrocZ
Engine: L98-ish
I've an old rail assembly I won't ever use. You can have it for shipping and a 6pack.
Car: 1987 Formula
Engine: 5.0
8Mike9 - Thanks for the offer... Let me see if I can use the replacement I just purchased. I may get back to you.
