Need help with code 43 and overheating.
Old Jul 14, 2019 | 01:59 PM
m300slr's Avatar
Car: 1985 Z28
Axle/Gears: 3.90 10 bolt eaton posi
So I haven’t driven my camaro or posted here in years ... I’ve started to drive it again and it runs great until eventually the temp starts rising to abt 220 deg and then the old check engine light comes on with code 43. Once the engine light comes on, the car starts rapidly overheating. Somehow code 43 and overheating are causing one or the other. I had an extra knock sensor so I put that in to the proper torque and I thought that fixed it but it did not. I haven’t noticed that it happens at any throttle response. I’m getting so frustrated and have checked the other posts fo a problem similar to mine, but haven’t found much mentioning overheating. The car does not overheat till code 43 comes up.... Any ideas you guys might have would be most welcome! I have a 85 305 tpi camaro with headers, slightly aggressive cam, and Bosch gen 3 injectors. I should also mention I have wiring from an 86 and a 87 ecm
JVince
Feb 1, 2011 03:03 PM
3gengirl
Aug 27, 2009 09:04 AM
sqzbox
Sep 28, 2003 10:03 PM
KED85
Feb 13, 2002 10:07 AM
Jax86SC
Jul 2, 2001 10:17 PM
