Can you identify this valve thing?
Old Aug 17, 2019 | 11:28 PM
R-Dog's Avatar
I'm changing out my fuel pump and found this thing sitting at the bottom inside of the gas tank. no idea what it is but I think it's some sort of valve.
Old Aug 18, 2019 | 08:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Can you identify this valve thing?
Looks to be the roll-over valve for the CCP vent line on the sender unit.
RBob.
Old Aug 21, 2019 | 05:58 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
RBob.
What RBob said. It also takes 2-4psi before it opens to relieve tank pressure which when it fails is likely the cause of so many posts about excess tank pressure when taking off the cap, or gas spewing out while filling the tank. New sending unit may be in order or can buy an external valve and put between tank and charcoal canister.
Old Aug 24, 2019 | 11:30 AM
R-Dog's Avatar
Thanks guys.
scottmoyer
Aug 1, 2024 09:29 AM
scottmoyer
Aug 1, 2020 01:11 PM
rusty vango
Aug 6, 2013 11:00 AM
rusty vango
Jun 12, 2012 06:47 PM
rob2000gt
Oct 25, 2011 09:21 AM
