Strange whistling sound from engine
I am currently hearing a rather loud sound coming from my engine, which sounds like a kettle boiling or a dog whistle. I don't know what is making the noise, but this coupled with my recent drop in fuel economy and power makes me think something is up. Also, about a week ago I heard a strange depressurizing sound in my engine bay that I had never heard before. I popped the hood a couple of minutes ago after hearing it whine all the way home, and I have a picture of where it is coming from. I have next to no knowledge of engine mechanics, so any assistance would be helpful.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Strange whistling sound from engine
Could be the idle air control valve
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
My IAC whistles a bit when cold on my new throttle body. Also check the EGR vacuum under the drivers side TB if its off it can whistle a little bit.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
One way to check to see if it is a bearing on the alternator is to get a mechanics stethoscope. But I think it may be a vacuum line. If it is a vacuum line downstream of the throttle plates then as you depress the throttle, manifold vacuum will decrease, causing your noise to disappear. Take your foot off the pedal, manifold vacuum increases and you hear the noise again. I had a problem similar to yours on my 76 Camaro many years ago. Discovered a cracked vacuum line.
Thanks for the help so far! I just turned the car on again to check and the sound is gone. I'll post again tomorrow, seems like it only wants to whistle when it's hot.
could be PCV valve if it is shot, they rattle inside a bit. my thought though is that if it changes with the throttle, i'm on team alternator.
BTW the facebook post screenshot there is epic!
Transmission: World Class T-5
Axle/Gears: BW 3.45
I did my best to take a better listen to the engine today, and I stuck my ear right up to the throttle body while the engine was running and that's where it was loudest, I heard nothing from the alternator. It seemed to be coming from right around the area where the throttle cables are attached. I don't know what would make a whistle here though. Maybe a bad seal?
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
I would suggest looking up the minimum idle set or IAC reset procedure. Force you IAC closed and run the engine. See if it changes pitch.
Also, does you idel seem higher now?
Get some starter fluid, start spraying suspicious areas and see if the RPMs picks up. * Don't soak the engine down, the ether is very flammable! Use it lightly in the area you want to test.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Are you data logging? Can you compare previous IAC counts to where they are now? Your leak may not be big enough to upset the idle (Yet) but the IAC isn't opening as much as it used to. Just a thought.
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I had a pcv valve that whistled real loud, pull it out and put your finger over it and see if the noise disappears.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The 5.0L in my '88 Econoline had developed an annoying whistle. No outward signs of anything wrong - no rough idle, etc. Didn't really notice a drop in fuel economy but being a truck it really isn't something that's on the radar.
Tracked it down to a vacuum leak in the plenum to manifold gasket.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Turns out it was the gasket behind the throttle body that was leaking. Anyone know where I could find one? I've looked online but I don't know the right size. Thanks for the help, and it's nice to see some humour in your posts lol
