Help reading spark plugs (pic’s)
Old Oct 25, 2019 | 08:12 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
I just finished installing a set of 2460 hookers on a 89 Lb9 5 spd. Right around 4K rpms I feel as if the car holds back, I assume is knock retard. I raised the Fuel Press to 50 psi and maybe it got a bit better, but not really sure. I pulled the spark plugs to take a look. Can some tell me if the plugs seem to be showing a lean condition?
thanks in advance.
Old Oct 28, 2019 | 03:21 PM
GeneralDisorder's Avatar
Re: Help reading spark plugs (pic’s)
If you are going to try to read plugs you need to start with brand new one's, do a test run, and then pull them out for a read. You can't really "read" old nasty plugs like that.
And yes if you installed headers and have done other modifications you may very well need tuning. I needed a lot of tuning on my 86 LB9 due to headers and 1.6 rockers. Caused a lot of detonation - that and the 3000 stall speed converter needed a LOT more AE to get against the converter without going lean and creating runaway detonation. Making the heads/exhaust flow better means you need less timing as the flame front propagation through the cylinder is improved from increased scavenging, etc.
GD
Old Oct 28, 2019 | 05:05 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
GD
Thank you for your reply, I will go ahead and replace the spark plugs. Also have a data logging tool on the way to get a better understanding of what is actually happening. I also have the 1.6 RR as you do, along accel base and runners among other things. Guess tuning is way overdue.
Sac
Old Oct 29, 2019 | 07:03 PM
84Elky's Avatar
Car: 84 El Camino
Engine: 360 TPI
Axle/Gears: 3.42 + Truetrac, Moser 28 Spline
What GD said +
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
http://www.4secondsflat.com/Spark_plug_reading.html
Elky
Tibo
Feb 24, 2008 11:12 PM
big tex
Mar 7, 2004 06:43 AM
Gumby
Aftermarket Product Review
Jan 21, 2003 03:26 PM
LeftTurn1LE
Jul 21, 2001 07:53 PM
