Engine cuts out under wot
Old Oct 26, 2019 | 09:59 PM
Liemar03's Avatar
Juat swapped a 1990 tpi engine into the car. Having an issue runs great under normal driving. But when wot it hesitates and then cuts out like it has a delay box in it and picks back up after a few seconds. Fuel pressure stay normal. All I know about the engine is that it has 24lbs injectors and he had eeprom burned by the company he back the conversion harness from. I did replace the map and tps sensor due to codes coming up. I've tried adjusting timing but doesn't help and rechecked all connections. Any help would be appreciated thank you
Old Oct 27, 2019 | 08:18 PM
Liemar03's Avatar
Re: Engine cuts out under wot
Can anyone help ?
Old Oct 28, 2019 | 02:00 PM
GeneralDisorder's Avatar
You need to data log the live data from the ECM. With it being swapped and modified there is no way to help you without knowing what the ECM is doing with fuel, timing, etc. It may be a problem or it may be a bad tune, or many other things.
GD
Old Oct 28, 2019 | 02:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
having a wide band gauge will help too.
you will be able to see the afr
beast94
Dec 5, 2012 02:19 PM
GusbZConv
Aug 27, 2010 08:58 PM
duratothemax
Feb 7, 2008 05:58 PM
YenkoST
Aug 9, 2007 02:14 PM
LIL QIK
Oct 28, 2004 11:41 AM
