Throttle body question
Old Oct 29, 2019 | 05:50 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I have a 88gta
And I have a 230k stock tb tpi
And it leaks vacum bad in the shaft seals the one at the spring return thing is the worse one
Is there any way I can rebuild it easily myself with certain orings
Or is it impossible?
Ty
Old Oct 29, 2019 | 05:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Throttle body question
You might try to locate a carb rebuilder and have bushings installed.
jayk2k3
Sep 2, 2008 08:24 PM
83crossfire
Feb 18, 2005 06:37 PM
IROC_5796
Nov 27, 2004 04:44 PM
