Underhood Fuel Lines
Old Feb 24, 2020 | 05:02 AM
rgauder's Avatar
Car: 1987 Trans Am
Are the underhood fuel lines with the rubber that go from the frame rails to the hard lines behind the alternator different between a serpentine motor and a non-serpentine motor. Thanks.
Old Feb 24, 2020 | 11:14 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Underhood Fuel Lines
Yes
Old Feb 24, 2020 | 12:10 PM
Drew's Avatar
There are a few different rubber hoses. Check the part numbers in the P&I Catalog. IIRC they're all the same thread, just some are shorter or longer. V6, TBI, TPI, should all come pretty close to being interchangeable.
Old Feb 27, 2020 | 08:06 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
On my 90 TPI, the lines were cut and grabbed V6 set at Pick N Pull and they are shorter but I see no reason that wont work as the TPI are so long!
Old Feb 27, 2020 | 10:00 AM
OrangeBird's Avatar
Car: 1989 Firebird
With a small cut off wheel , a few hand tools , and a trip to your local autoparts store , you can make your own of any length you choose that will work just as well as the original ones . Of course , you must use both hose and hose clamps rated for fuel injection service and you need to have skills enough with the cutoff wheel to only cut the outside crimp holding the hose to the inner fitting , and not to cut or otherwise touch the inner piece of the fitting (that you will clean up and reuse) . What you see in these pictures was done 10 years ago , and I only just recently replaced the rubber as a preventative maintenance measure while I was replacing the (also 10 years old) radiator hoses .
Old Feb 27, 2020 | 10:31 AM
Drew's Avatar
Or have a hydraulic shop crimp your existing fittings to a new length of hose.
Old Feb 27, 2020 | 11:01 AM
OrangeBird's Avatar
Car: 1989 Firebird
Yep , could do that , but then you can't change the hose yourself , your bound to having a shop crimp them for you . I see no reason why my method , with two fuel injection rated hoseclamps at each fitting , isn't as good as the non serviceable crimp . Unless of course your going for the factory look of the original crimped fittings , which on my daily driver (that'll never see Barrett- Jackson unless it watches it on TV) is just fine for me .
Old Feb 27, 2020 | 01:24 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
as long as the length allows use, they will werk
Old Feb 27, 2020 | 01:33 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Would it be a worthwhile idea to use a flare tool to put a bit of a lip on the end of the reused fitting to prevent the hose from sliding off ?
Old Feb 27, 2020 | 02:20 PM
Drew's Avatar
There's nothing wrong with your fix. The brand F thing in my driveway, which technically qualifies as my daily driver, has EFI hose and EFI hose clamps clamped onto the OE Ferrrrd QD fittings. One clamp per connection. Been that way since 2006? zero problems.
Jhook
Jun 12, 2018 07:57 AM
91greenbird
Carburetors
Dec 8, 2006 02:37 PM
spills
Carburetors
Feb 27, 2006 08:11 PM
pandorafowler
Apr 29, 2005 09:51 PM
